TwinTurbo.NET: Nissan 300ZX forum - Yes the actual ignition lead at the starter that energizes
YlwPrlZTT
on November 19, 2013 at 3:03 PM
Which lead are you referring to?
posted by spicyZ
on November 19, 2013 at 08:36 AM
the starter relay. Turn the ignition switch to on and check voltage at that lead. Do you have any other starter you could try out just to rule it out 100%?
Car won't crank after 60K
spicyZ
08:54:50 11/18/13
Re: Car won't crank after 60K
Rasta420
09:17:10 11/18/13
Re: Re: Car won't crank after 60K
spicyZ
09:30:00 11/18/13
The hood sensor switch is on a bracket that sometimes
zellamay
10:30:20 11/18/13
Did you run power directly to the starter, and did the
zellamay
15:04:54 11/18/13
Did not run power directly to the starter..
spicyZ
15:14:58 11/18/13
Have you measured the voltage at the starter ignition
YlwPrlZTT
20:02:07 11/18/13
spicyZ
08:36:37 11/19/13
Yes the actual ignition lead at the starter that energizes -
YlwPrlZTT
15:03:32 11/19/13
Will get this checked
spicyZ
11:46:01 11/20/13
Did you check your clutch switch on the pedal under
CmyZ
21:49:10 11/19/13
Checked clutch switch yes
spicyZ
11:45:25 11/20/13
Was the security light on?
-Grimm-
11:52:52 11/20/13
Security light isn't working at all
spicyZ
12:28:34 11/20/13
